Old 10-25-2012, 09:08 AM
pete240 pete240 is offline
Default Electric PTO
So I've read that you can replace the bearing on an electric PTO, but what about the coil? Mine is destroyed.
Old 10-25-2012, 12:05 PM
Gaden's Avatar
Gaden Gaden is offline
A good place to start is partstree. You can get the part number you need from there, then use those in search to find the best price.
Old 10-25-2012, 12:10 PM
cubs-n-bxrs's Avatar
It's probably going to be cheaper just to buy another PTO and a lot less headaches.
Old 10-25-2012, 12:51 PM
Gaden's Avatar
Depends on what kind of shape the rest of the clutch is in. For my 1872 on partstree, the entire assembly is about $300 more than the field by it's self.
Old 10-25-2012, 04:17 PM
It's possible to rewind it...I've seen it done. I have yet to try it though.
Old 10-25-2012, 04:47 PM
You might try the Sponsors at the top of the page and see if they have a good used one.
Old 10-25-2012, 04:59 PM
I was happy to find that they do sell just the field coil. Its still pricy at around $180 but it sure beats over $500 for the whole new assembly.
My next question: I know there should be a fuse somewhere, that spot was bypassed on this tractor, im guessing the wire leading to the pto should be fused?
Thanks for all your help guys
Old 10-25-2012, 05:12 PM
In looking at your original post, you make NO mention on the model of tractor you are working on.
In general, there usually a 10A fuse in the PTO circuit.
Old 10-25-2012, 06:21 PM
Gaden's Avatar
Use the part number you found and enter it on any search engine (or directly in the address bar), it takes a little time to sift through the results, but it payed off for me when I needed a new armature, saved over 40 bucks.
Old 10-25-2012, 06:27 PM
ajgross ajgross is offline
Inactive Member
Why don't you look for a used pto. You should be able to pick one up for $75 or less.
AJ
