Old 10-27-2012, 06:18 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Default Tire pressure using chains
I installed my chains today, and wanted to know how much air pressure to run in the rear tires when I use chains. Usually I run about 10 to 12 psi in my 23-8.50-12 turf tires. Should I increase the pressure while using chains?
Thanks in advance!
John
Old 10-27-2012, 06:46 PM
I've always used the same tire pressure. You want a flat footprint to maximize grip, increasing the air pressure would crown the tire reducing the contact patch.
Old 10-27-2012, 06:59 PM
Yup. I have about 7 in mine.
Old 10-27-2012, 07:15 PM
I would not use less than 10...it's possible to hook the chain on something and pull the bead off the rim if the air pressure it too low.
Old 10-27-2012, 07:51 PM
tractordude tractordude is offline
Let the air out of the tires, put the chains on, get them tight, and refill. they will be nice and tight
Old 10-27-2012, 08:30 PM
cubfixer's Avatar
Excellent advice! Thanks to all!
John
