#21
![]() ![]() ![]() Quote:
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
#22
Post a pic of the problem area, I have a couple ideas.
#23
Looks good so far.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
#24
Here are some pics...
![]() ![]() ![]() Here are some pictures of todays progress... I scraped down and wire wheeled the frame today. ![]() ![]() And Made a new wiring harness! It just needs new connectors
#25
In another 50 years, that shaft could wear to the point of needing attention!
![]() John
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
#26
John, I totally agree with you, but I am trying to restore it to the best of my ability, the brake/clutch pedal has alot of slop in it when it is in place, just looking to minimize that.
#27
You could always build up the shaft with a few beads of weld and belt sand it or draw file it down to size.
#28
That is exactly what someone suggested to me!
I will give it a try
#29
Great progress you're making
![]() Question regarding your wire wheel. What are you using? I've had poor luck finding a "good" wire wheel for my bench grinder, they just don't last very long. I turn them every so often so they don't flatten down, and they also work better with less force once flipped, but they don't seem to go far before the wires start flying out. When I was young, over at our company's shop, they seemed to last much longer, but I suppose like everything today, nothing is built as good as it used to be. Sorry for jumping your thread, but any thoughts? Thanks
#30
Cory,
Nice progress! Where did you get the braided nylon for your wiring harness? John
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
| Thread Tools | |
| Display Modes | |
