Old 01-01-2013, 05:13 PM
cubby102's Avatar
cubby102 cubby102 is offline
I've got loaded 10.50s on my 782 with ih style weighs on the inside and black 50 lb plastics on the outside and I'm making up a salt spredder for the back of it plus my 200 lbs on the seat I havnt noticed any problems a couple of my buddy's are running a lot more weight then me and have been for years no bad effects on them eather
Old 01-01-2013, 06:39 PM
Originally Posted by litlmikeyl View Post
I have a feeling we're underestimating what the bearing in the axle tubes will carry.
I can dig a book out and check the exact numbers, but as a general rule, doubling a load on a (rolling element) bearing will reduce the life by a factor of 10, IIRC.
I'm not sure how that works for the earlier tractors that have bronze sleeve bearings instead of roller bearings.
Old 01-01-2013, 09:03 PM
nikster's Avatar
nikster nikster is offline
The best way to add weight is loading the tires and wheel weights. That is rolling weight. Hanging weight on the back plus body weight adds to the stress on the wheel bearings.
On my 125, I have loaded 10.50s, a pair of gilson wheel weight 65 x2=130 plus my 210 lbs.
As someone else mentions, rolling weight is the way to go as opposed to dead weight for weight distribution. Less friction on gears, bearings,
Nik
Old 01-04-2013, 02:06 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Matt, your figures sound correct given real world experience. That brings up another question. Given we're discussing how much weight to carry on a tractor, I'm curious to what frequency guys carry the amount of weight they posted they use. Does it stay on the tractor all the time or just for specific activities.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
