Old 01-06-2013, 06:55 PM
ScubaDiver1969 ScubaDiver1969 is offline
Default Add more weight?
I have a Cub Cadet LGX1054 and have put a MTD 42 inch Snow Thrower attachment on the front. I have added chains to the tires and suitcase weights to the back. How much weight should I put on? I have about 60 lbs added already. I am noticing that while turning the front end will slide and not turn unless I lift the snow thrower attachment an inch or so off the ground. Then it will turn fine. Suggestions?
Old 01-06-2013, 08:59 PM
I have heard of people putting chains on the front wheels to get more grip.
Old 01-06-2013, 10:48 PM
cmatthew's Avatar
cmatthew cmatthew is offline
get some nice rib tires up front. those skids on the blower are acting like rails. keeping the blower going straight and hard to turn. some wider flatter skids or shoes on the blower would help with turning it. mking it slide better for turning.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 01-07-2013, 08:27 AM
I would load the rear tires as well.
Old 01-08-2013, 06:20 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Load'em up like Methos said. And the good advice of bigger shoes, along with ribbed tires both are a big help.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 01-08-2013, 04:08 PM
Thank you all for your suggestions. I'm going to go with the ribbed front tires and loading the rear tires. I'm looking for wider skids as well.
Old 01-08-2013, 10:13 PM
Jameseric Jameseric is offline
Last year I found a guy that makes skids to order on eBay. I Have two sets...sorry I do not have his contact information.
