Old 01-08-2013, 04:29 PM
martyrant martyrant is offline
Default Hydraulic Cylinder information for the 42/54" plow
I had found this thread: http://www.onlycubcadets.net/forum/s...hydraulic+plow
and I just looked on partstree to see if I could find out what size bore/stroke the cylinder had to be (I know it's double acting). I had seen someone post one in that thread that was 1.5" bore and 6" stroke, but wasn't sure if that was the correct information--does anyone have the correct information on that part?
Trying to see how much it would cost to make a non-hydraulic plow hydraulic.
Thanks
Old 01-11-2013, 10:26 AM
I think I found a wide frame plow and will be making the trek to pick it up this weekend; anyone out there have the hydraulic information for the kit or the hydraulic cylinder used in the kit to make it a power angle plow?
I found these hydrualic cylinders to be pretty reasonable.
Thanks in advance.
Old 01-11-2013, 10:31 AM
That sounds about right...
Personally, I can't see the heftiness of that cylinder just to angle the blade.
Old 01-11-2013, 10:36 AM
Yeah, I went on youtube and watched one fully extend/retract, and it looks like the stroke is somewhere between 8-12" though, I think 6" is too short. I'm thinking it could even be 12", just not sure.
EDIT: Went back and watched the youtube video and you can't see the cylinder I guess, but the blade does move quite a bit. Hopefully someone on here might have one and have the info.
Old 01-11-2013, 11:06 AM
According to the CPE-2A Manual, it says 1-1/2" x 7-1/2"
Old 01-11-2013, 11:10 AM
Awesome, again, thank you Roland! I think the 8" stroke might work out then, the 6" might be a little too small. This guy for future onlookers.
Old 01-11-2013, 12:45 PM
Darrell Darrell is offline
Pretty sure there is two different sizes on the ram for the cylinders.
I think when the cylinders came out for the QL's , they had the smaller rams.
Somewhere when the 82 series came out is when they went to a bigger ram. Not sure if the cylinders are all the same size ??
I have an angling kit and the ram is smaller than the one in Rolands pic.
Old 01-11-2013, 12:46 PM
Gaden's Avatar
Gaden Gaden is offline
I have to disagree, since the cylinder holds the blade at whatever angle it's set at, it would need to be fairly hefty. It would have to withstand any pressure applied to the blade.
Old 01-11-2013, 02:00 PM
Mcamp Mcamp is offline
The early hyd. angle cyl. for the quiet lines were a smaller cyl and ram and were prone to bending on the 54in. blade. the 82 series have the larger cyl. and ram as in the above pic. Mark
Old 01-11-2013, 02:15 PM
Do you know if this cylinder would handle a 42" or a 54" blade? It looks pretty solid.
