Old 12-21-2009, 02:02 AM
wig wig is offline
Default Tiller gear-box on 782 Question
I am new at this and have a question about leaving the gear-box mounted on the tractor. I want to get ideas from viewers if the gear-box is generally always left on the tractor year-round or do guys pull them off when not being used. I thought it would be a little extra weight which would be ok for traction in snow, etc. The problem I see with taking it off is when you loosen the lower bolts on the mounting bracket to the rear axle housing cover you will loose hytran fluid (which is not cheap). What do you think?
Old 12-21-2009, 08:44 AM
eastonct124's Avatar
eastonct124 eastonct124 is offline
I always removed it, because it hangs pretty low, and I don't want to damage the pulley while going through the woods hauling timber.
And, I'm not sure if it's correct, but with the rear gear box, the ball mount is a few inches lower, than when it's mounted directly to the diff.
I'd leave it on, if you don't do the kind of offroad work that my 124 is used for.
Fly Fishing is not a sport...It's a way of life.
Old 12-21-2009, 10:27 PM
Darrell Darrell is offline
Wig , It's a no-brainer !!! Get another Cub and use it just for tiller duty.
Old 12-22-2009, 07:17 AM
I am with Bill, the Tiller Gear Box on my 1450 stays on all year round for the same reasons you cited. It is time consuming to take on/off and the loss of fluid are the issues for me. I have had mine on now for 5 years.
