Old 02-22-2013, 04:41 PM
ramman16248 ramman16248 is offline
Default ATV tires on a Cub Cadet
Has anyone here used the ATV tires on the rear of their cubs and used them for mowing? If so, could I see some pics please? I am looking to maybe put some on my 1210. I am looking at possibly the 25x10x12 maxxis. It is the closest I can find to my 23x10.5x12 's without going too skinny. Thanks, Jason
Old 02-22-2013, 04:44 PM
sawdustdad's Avatar
Why do you want to do that?
Old 02-22-2013, 04:58 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
i 2nd that????
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 02-22-2013, 05:16 PM
vartz04 vartz04 is offline
Better traction than turfs but still easy to put chains. Like a step between turfs and ags
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 02-22-2013, 05:47 PM
Exactly, plus the price of them is a little better than the garden tractor tires. John Deere is doing a very similar tire on theirs now from the factory. I just don't know how they work. My yard gets a little wet though the spring/fall and the ags I have had in the past dig pretty bad. I mow with it, and I don't plow. the current turf tires are dry rotted and I would get stuck at the slightest hint of water. I figured if these were cheaper and worked as well, why not.
Old 02-22-2013, 05:54 PM
My dads 4x4 jd 585 has the tab style tires on it. They work great even in 2wd he has a very hilly yard and a steep banked pond. Handles all of that in 2wd no prob and pushes snow with no problem in 4wd and no chains. I've been considering the same tires myself but I'll probably end up with ags
Old 02-22-2013, 06:04 PM
Plus, even though these are a little more agressive than I may want, they look really cool too!!! (Even if they are on m green one.) Not my machine by the way, I found the picture on the net.LOL!!
JD112 by gearhead16248, on Flickr
Old 02-22-2013, 08:01 PM
OldSchool81's Avatar
OldSchool81 OldSchool81 is offline
Traction is traction. If it will work go for it.
Old 02-22-2013, 10:29 PM
mmzullo mmzullo is offline
I buy them all the time. Used on CL more then enough tread for our tractors left on them. I even bought 2 full set brand new that they changed to a different set. 100 for a set! I have 1 set on my loader and other on my 1811. 1 set on my model 70 ans 6 more in stock for future tractors. Here are some pictures.
Old 02-23-2013, 09:43 AM
I have a 1641 with turf type ATV tires on it. A friend put them on the tractor because he sold ATV's and got a good price on them.
I bought the tractor from him but never cut grass with it. All I remember about it, the tractor rocked around quite a bit with the soft tires on it. They were also taller than the standard tires.
I guess they worked okay as the PO used the tractor for a couple years after he installed the tires.
