Have anyone ever used sea foam before. I have and that was with the 100 before the red and white. Or when it was original. The old ten horse seemed to gain more power again after i put some in it.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
I use it in all my small engines even my Harleys. No idea what they make it with but it works. Great stuff if you have a carb that is crappy.
I use Sea Foam in all my small engines also. It is just a good all around engine treatment and stabilizer.
I use the stuff all the time at work on lawnmowers and Garden tractors. It works great for the fuel system.
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
I just wish it wasn't nine bucks a can.
I have a question. I use MMO and Startron. Can you put too much extra stuff in todays fuel?
Keep dragg'n em in. They're like orphans...they all need a place to call home. |
At a plow day I tried sea crap and my 100 would die and 149 was way down on power. I drained the gas out of both and replace gas that didn't have sea crap in it. Both ran like they should.
I known a few that swore by sea foam. The stuff does break loose carbon build up. Two Kohlers start using oil after the sea foam treatment. I wouldn't use snake oil products like sea foam. There is no quick fix in a can out on the market.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
I have never have had a problem with any fuel treatments or additives.
I've tried Seafoam and have never noticed any difference in performance or operation. I will just stick with treating my fuel with Startron. Every air cooled engine I own runs better with Startron treated fuel. Cold starts in the winter is where it is reall noticed.
Gee Dale lets not pull any punches Sea Crap LOL
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
| Thread Tools | |
| Display Modes | |
