Old 04-15-2013, 08:27 PM
79Puller 79Puller is offline
Default Power steering ?
I again have a couple questions, How do you check the power steering fluid on a 2182 ? And I read but cant find that the plastic on these models can be replaced with tin from another model. What models should I look for and is this a bolt on deal. Again thanks for all your advice.
Old 04-15-2013, 08:43 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
power steering is powered by the hydro so check the rear end fluid. as the other i don't know what will fit.
Old 04-15-2013, 08:57 PM
Tin is not a bolt on. Hood & grill are available, side panels are not available from Cub for the 2182 but you can use side panels from the 1864 but you will need to cut the openings that are unique to the 2182
Old 04-15-2013, 09:01 PM
cub123's Avatar
cub123 cub123 is offline
Yup, the power steering is run off the hydro, as far as a a bolt on tin swap...it's not going to happen, a great deal of work would be required to put 82 series tin on one even though the frame is the same, especially with the rear mounted radiator on the 2182.
