Old 05-10-2013, 08:51 AM
Cjbdvm04 Cjbdvm04 is offline
Default Neutral safety switch
I was looking around to find a replacement for my 127's neutral safety switch that was seized up. After doing searches on "momentary push button switches" I found that these are rather standard switches that can be found anywhere. I ordered one on fleabay for about 8.00 with free shipping instead of nearly 40.00 for an original. This one is a Moroso 74120. Most of them come with the same 5/8-32 threading of the original and also come with the protective boot. If the mounting depth isn't correct you could take use one additional hex nut to sandwich the switch to the mounting hole at the correct depth then put the boot over the top. Otherwise, you could bend the safety flapper to properly adjust switching point.
File Type: jpg $T2eC16J,!)0E9s37F,GdBRb82doZw!~~60_12.JPG (9.5 KB, 273 views)
Old 05-10-2013, 08:52 AM
Just to add: The contacts on this one are screw posts so the end connectors on the wires would simply be changed.
Old 05-10-2013, 08:53 AM
When ordering, be sure to find a switch with "normally off" so that when the brake is pushed it completes the starter circuit then turns off when the brake is released.
Old 05-10-2013, 09:06 AM
donnelly.me's Avatar
donnelly.me donnelly.me is offline
That's a good tip. I like it anytime someone shows me how to save $$$. Thanks
1973 Model 149
42" Snow Blade
John Deere X360
John Deere 10 cu Poly cart
Squire Applegate 5HP recoil start
Old 05-10-2013, 10:13 AM
Absolutely! I like trying to support the sponsors but I find that the prices for some of these original Kohler/Cub parts are INSANE. Just like the crankshaft end bearings; just a standard 6008 bearing for $20-30 instead of $80-90 for OEM.
Old 05-10-2013, 10:38 AM
I think the reason 90% of the OCC members are here are because we like to save $$$
I read on another forum about the guys spending $8900 for a 60" cut mower, What fun is that?
I do not think I have spent $8900 on Cub Cadets, and I have owned a LOT of them since 1980.
Great find on the switch!!
Old 05-10-2013, 12:35 PM
This switch can be replaced by numerous switch Manufacturers, ie: Carling, McGill, etc.
Old 05-10-2013, 03:53 PM
Maybe McGill has one that will fit but the 100s is a 15/32-32 threading so it may be a bit sloppy in that hole.
Old 05-10-2013, 07:04 PM
Am I the only guy that just bypasses this switch and treats the machine as a gun? AKA "Always loaded..."
Old 05-10-2013, 07:39 PM
LOL.....Nope
