Old 01-24-2010, 08:09 AM
tostir tostir is offline
Default Another 1650 Starting Issue
In working on my 1650, I noticed that there was no clearance between the exhaust valve and the tappet - the manual says .017/.019 for exhaust. My father-in-law had made adjustments to this valve before I received it. I made the proper adjustments, just before the my starter issues (previous thread) crept up, so I haven't had a chance to see if things work better. Would the lack of clearance between the tappet and exhaust valve cause a hard start due to the automatic compression release function on the Kohler 341?
Old 01-24-2010, 08:32 AM
If the clearance was too slim to nothing, it would raise the exhaust valve higher than normal, and you might be getting into a "carboned up" area of the valve, causing some sticking.
You might want to try some of this in your Fuel Tank....
Old 01-24-2010, 09:07 AM
Thanks for the advice. Would the exhaust valve opening too far have any effect on starting?
Old 01-24-2010, 09:29 AM
YUP.....you would have less compression to none at all.
