I did pull the yellow wire off of the M, key switch and also from the side of the motor where it attaches to the wire from the armatures. I was told it was a Kill wire for the motor. It still has no spark or fire. Im in the process of looking at all the wires again to make sure nothing is crossed. Im certian it doesnt take any wire to make a spark, just the stator, armatures and starter. I think I have something hooked up wrong..looking at my wires
Sounds like you have a bad Magneto(s).
The Stator is for "charging". The "starter" is for rolling the engine over. I am not clear on what you mean by armature. However, none of these three items have anything to do with the "spark".
Im not sure bedell. This is the third(second one I broke) one I bought from briggs. It just has 4 bolts and two yellow wires that has a connection already on it that plugs into my votage reg. Im almost done tracing all the wires and bout to hook them back up. I didnt find anything wrong.
Where does the wire from the armature go? is it a ground or hot? Does it connect to the yellow wire thats already ran and connected to the housing? |
Briggs calls the Mags Armatures, don't ask me why.
Yes I did replace it with a homemade wire. I didnt see no diode in it since it was all broken in pieces and chewed up from the flywheel.
My guess is if you remove your wire it will start and as long as you have the fuel shutdown solenoid wired correctly it will shut off but it will take a few seconds to shut off. You will need the proper wire harness from Briggs in order for it to function properly.
Just sent you a pic to your e-mail showing how a Vanguard is wired.
Sam Mac you was right. I cut the wire that I made and it started but only was running on one cylender. Im in the process of ordering a new wire as we speak. Its been an agravating week but at least its running.
Thanks for the Vanguard Diagram, I will definetly use it. Im thinking of restoring this whole machine this winter. Its a great mower and thanks for everyones help. |
I am going to move this thread to the MTD CCC area since this is turning into more of the how do I fix this type of deal.
I had the same issue with my Vaguard. There is a diode in each wire that goes to each mag. Go to Radio-shack and get 2 $2 diodes and put them in each kill wire. The ones I picked up are rated at 1000 volts @ 1.5 amps. The new harness that came with my mags didn't have them in either. The diode keeps them from grounding each other out.
| Thread Tools | |
| Display Modes | |
