Hi guys- got the 1450 running today. Onto the next two problems- first is the hydro lift lever. It does not move forward or back. Any ideas? Second, it almost sounds like the driveshaft is loose. Only makes noises in motion. Thanks for the help guys
I bought a 1650 that had the same problem with the lever and the small piston that the chain is hooked to had some rust around it and wouldn't move.
A few days of PB Blaster and GENTLY moving the handle back/forth freed it up. I think i did get tired of the GENTLY stuff and got kinda rough with it and it broke loose. Just try not to break something !! Not sure what you mean about the driveshaft ????? |
For the driveshaft take the 4 tunnel cover bolts off and have a look. My rag joints were shot, especially up front where there was only one. When I replaced them I red rilles the sproil pin hole and added a second rag up front. About a $50 repair. My rag up front was an oval.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood. |
Check and see if the rear end is loose in the frame. That could be causing the driveshaft noise.
So I got the lever free, and the hydraulics work! Now, I have to figure out what size belt I need for the deck, and how to turn the pto on.
| Thread Tools | |
| Display Modes | |
