Old 07-27-2013, 08:19 AM
eddy622611 eddy622611 is offline
Default 44 GT deck problems
I have a model 44 GT 318 190 serial 410 028 that has been mowing poorly. The cut is uneven and it clogs quite often. I removed the blades to clean the deck better and the spindles seemed loose. When I took off the deck belt the shafts pulled right out the top. I tried to search for parts diagram and failed.
Can someone supply me with an parts diagram for this spindle. Thanks,eddy622611
Old 07-27-2013, 08:25 AM
Go here............... Cub Cadet Parts Look Up
Type in: 190-318
Old 07-27-2013, 08:59 AM
Thanks, I was entering 318-190 with no luck.
Old 07-27-2013, 09:16 AM
Most Cub Cadet Attachments & Implements start with "190".
Old 07-28-2013, 09:11 PM
I took the spindles apart and cleaned the bearings. They look to be in good condition. I'm just going to repack them and replace the seals. Looks like the seals are the same top and bottom. cc p/n 921 3018a Hopefully I can pick them up downtown at NAPA.
Old 08-18-2013, 09:35 AM
After 4 trips to the CC dealer, I have all the parts to put my deck back together. Spindles are rebuilt and back on the the deck. I am ready to install my new blades. I need to know what I should torque them to? Other decks call for 55-60 ft.lbs. I can't find a manual for this though. Thanks,eddy622611
Old 08-18-2013, 09:38 AM
I have never torqued my blades on. I simply tighten them using the "armstrong" method and never had come loose or off.
Old 08-18-2013, 09:48 AM
Thanks, Roland I never have either. On this deck it seems that when you install the blades it preloads the spindle bearings. I was concerned about making the bearings too tight. eddy622611
Old 08-18-2013, 01:30 PM
I use the impact. They don't preload the bearings, there is a spacer between them.
Old 08-18-2013, 06:42 PM
Thanks, Sam thats what I did and it worked fine. eddy622611
