Old 10-09-2013, 09:41 AM
Hydro lift was an option for the 109/129 for $145.00 according to 1973 price list.
Up to 534 and counting...
Old 10-09-2013, 01:48 PM
martyrant martyrant is offline
Something is odd here............The 1250 NEVER came from the factory with a Hydraulic Lift. It was strictly "armstrong". Now, has a hydraulic lift been added to this 1250 or do you have something other than a 1250...???
My 1250 I bought with dual hydraulics. I'm pretty sure it may have came factory that way...but a PO might have added it.
From the 1975 Quietline Sales Brochure.......As a note.....I did NOT realize, that the 1250 could have been fitted with a Hydraulic lift as an option.
Hey Roland! That's actually my exact one two levers, dual hydraulics.
Old 10-09-2013, 01:49 PM
This would be the problem. Had the same issue on my 1450.
After several attempts to tighten the bolt on the #4 Lever, I welded a collar w/ set screw provision to the #4 Lever and ground a flat spot into the Hydro Lift Lever......Problem Solved. Hopefully you can just tighten that bolt. BTW, that bolt should be Grade 5 or stronger if you are replacing it.
Thanks guys!
I will give this a shot and come back and report.
Always a pleasure dropping into these forums...always great people and great knowledge!
