Old 10-11-2013, 08:36 PM
scottmi65 scottmi65 is offline
Default KT17 Backfire
My series II started backfiring today at all throttle settings. Just wondering if it is in the ignition system. I timed the engine with a timing light a couple months ago when I replaced the points and condenser could the coil be going bad?
Any ideas would be appreciated.
Old 10-11-2013, 09:48 PM
young enthusiest's Avatar
Yes. coil is one of the possible causes. does it start hard? does it kick hard, shake a lot, and run rough? was it a somewhat sudden onset? It is quite likely the coil has about had it, and is shorting out and firing when it is not supposed to.
Old 10-12-2013, 12:23 AM
Back-firing out the exhaust? Or through the carb?
Old 10-12-2013, 07:08 AM
Backfire is out the exhaust. Rough running and it starts hard. It seems to me on cylinder is not firing.
Old 10-12-2013, 08:16 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
check for spark on both sides, and while your checking make sure it has compression on both sides. since its a KT
Old 10-13-2013, 12:03 AM
I agree. And I bet you will find low compression on one side.
Old 10-13-2013, 10:37 AM
I checked compression this morning, 100 on the left 120 on the right. I have spark on both plugs.
Old 10-13-2013, 11:00 AM
Pull the head on the side that is low. It has an exhaust valve problem.
