Old 10-12-2013, 11:42 PM
Originally Posted by a79fordman View Post
I'm planning to build a 1712 super with loader. I was given a Mazda rotary engine. I'm thinking that it might make a great power plant for this tractor.
A 1712 isn't a super...... and rotary engines are gut-less under 6000 rpm
Old 10-16-2013, 11:19 PM
a79fordman a79fordman is offline
Yes, I know that a 1712 is not a super. But that don't mean I cannot make it one.
Well I don't know if my rotary engine will be gut-less under 6000 rpm. But the way I plan to run it. I will be able to run it at most any rpm. It is the engine I have & I would just like to try it.
Old 10-16-2013, 11:42 PM
The hydro will explode over 4000 RPM. I think you need to reconsider. Good luck with that.....
Old 10-17-2013, 12:03 PM
fpatd's Avatar
fpatd fpatd is offline
Aside from the rpm problem, you won't be able to muffle the noise from that bee stinger you will need ear plugs + ear muffs & a helmet + all sorts of body armor to protect you from all your neighbors throwing stuff at you !
Old 10-18-2013, 09:54 PM
I alreadly have a plan to get around the hydro blowing up at 4000 rpm's. ( I know that problem) It's very easy, Don't use it. LOL My idea right now is to have the engine run a hydraulic pump. The pump will put power to my loader, three point, and the hydraulic motor that will drive my manual shift rear end. I know this is not a fool proof plan, But I know it will work.
Also about the lack of power. The engine I have is rated a 90 hp I think. Now that is at a higher rpm. But still, It should have more then enought hp to move my little cub.
Also, I find no reason why I can not muffer my engine down. Might be a little loud, but load is fun. LOL
Old 10-18-2013, 10:23 PM
Ok. I have been working of equipment and with hydraulics for years. There isn't a pump out there that I have ever seen, and I've seen a lot, that will handle over 4000 RPM. So, you are going to have to gear it down. If you do that, you just as well use the hydro. Also, putting a hydraulic motor on the front of a gear drive, will be impossible to control. Hydrostats are designed and built with feather touch control. You won't be able to have enough control to drive a trans like that. But, you seem to have all the answers, so have at.
Old 10-19-2013, 09:42 AM
Jumper Jumper is offline
Just a few re-power idea's .........
Old 10-19-2013, 08:44 PM
fourinchdragslicks fourinchdragslicks is offline
I sure do like that hit and miss, would be pretty sweet to see in a narrow frame
Old 10-29-2013, 10:17 PM
how about a wrecked harley v-rod..??..liquid cooled...
Old 10-30-2013, 06:52 AM
That's funny, I looked at my Night Rod the other day and thought about this thread. Good thing my bike is not wrecked.
