#31
Maybe you're right and I am taking forr granted my mechan ical background.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
#32
Bottom line is that you are only held back by yourself. Nothing in doing work on these machines is rocket science, these machines are all at least 30 years old. All they require are YOUR willingness to learn a little and get dirty. If they are together right they run, if not take it apart and try again.
These are not like your car, if it takes a little longer than planned you are not stuck at home because it is not running. Take your time and learn, HAVE FUN!!! There is no shame in not getting it right the first time every time, there is not a pro out here that has. |
#33
I do all the work on my IH Cub Cadets. The only thing I haven't work on is the hydro pump on a hydro Cub Cadet. I have rebuilt engines, clutch assemblies, transmissions and rear ends and the add on hydraulic system for narrow frame IH Cub Cadets.
This is the last IH Cub Cadet I did: http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick I try to do a play by play on rebuilding a IH Cub Cadet. I've been a machinist for 35 years. I still take any engine I'm rebuilding to an automotive machine shop to have cylinder and crank work done. I have rebuilt several engines and clutch systems in the past. I hope to do more engines starting next spring. I charge a flat rate when I rebuild an engine or clutch. When an owner picks up his rebuilt engine they will get sheet with before and after measurements of the cylinder bore, crank journal and valve clearance.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
#34
#35
So far I have done all the work on mine. I have had alot of help and insight from people on this website. Our cubs really aren't that hard to work on. Some folks are better at engines some are better at electrical,some are great at hydraulics and differentials. Electrical is where I fall short,but am getting better,engines and carbs are pretty easy to figure out. I did all the painting on my 1200 and had never painted and asked alot of questions and got alot of good advice from members Of OCC.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
#36
My dog actually does all the work on my cubs,other than machine work on the motors,I just watch and pay her in dog biscuits.
#37
LOL Lew
#38
I think that would be a great winter project for myself. Buy a blown or dead motor, take it apart & see what makes it tick? ![]() NIK,
It dont cut grass, but its yellow. |
#39
Jenn and I do some work, but we need help with the hard to see things.
| Thread Tools | |
| Display Modes | |
