#21
Just looked at the install directions for the valve kit for the Cyclops and they only mention 1 O-Ring on each side of that adapter, maybe the 3000's are different. Can't say because I have never seen one.
#22
The 3k tractors only require 1 ring per side also. I will get the adapter and some rings out to you this week Sam.
#23
I would be interested a pair of them as well.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
#24
Big thanks for this post Just checked pricing on a bunch of seals and gaskets I need for my 1782, www.cubcadetpartsnmore.com had better pricing than every other place I looked at.
#25
SamMac, I would like one of those adapters also please.
The diagram for the 365 3-point hitch shows a 721-0492 oring backup in addition to the 721-3021 oring on each side of the adapter.
___________________ Jim 782 w/Command 18, 1862 not running; IH 42 inch blade; off brand cart |
#26
Hi Sam,
I would like whatever is needed to convert my 1882 as well. If you can please PM me when your ready. Thanks Mike
1991 1882 |
#27
Hi Guys,
I am trying to do this exact same project to a 2084. Just picked up a plow for it and want to make it fully hydraulic. Any help would be great. Sam - you don't happen to have another one of those valves laying around do you? I see I just missed one on eBay a few days ago :-( Also, this part you are having made is what stacks these valves together, right? If so, I am in for 2 of them! Thanks guys! |
#28
I looked at the 3000 blade angle kit that required adding a valve. That is where I got the opinion that it needed both o rings and back up rings. I may have been wrong, but only wanted to do it once.
#29
SamMac- I just re-read these posts and realized I should have asked you to reserve 2 of the adapters for me rather than 1.
Thanks!
#30
Sam Mac or anyone else, can you confirm that the part number I need for and additional hydraulic valve for my cyclops SGT, model 2084 is 717-3308a?
Then I will just need to make a handle to operate the valve, correct? Thanks for the help guys! |
| Thread Tools | |
| Display Modes | |
