Older Case tractors had them....I just seen 3 at an auction today.
I think they had the "wide base" block in the case though didn't they? They won't fit in the cub. There were two different K341 blocks. A narrow base, and a wide. If there were others I don't know.
I just bought one of them 341's last week for $20 from a friend of mine. It had been in a flood but was very saveable. It had the wide base block bottom. I traded it to someone else for a very low hour HH100 Techumsah engine for a MF10 I am going to restore. I didn't check the block bottom but wonder if a cub oil pan would fit one.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
JD's and Wheelhorses use the same oil pan setup ,but to use it in a cub I was told you need to weld up the block,then put a cub one on it.PTO end is larger than a cub also.
That question was brought up here not too long ago, Don Voit (dvogtvpe) said the blocks are different. I didn't know that until then. As many engines as he's rebuilt, I'd say that is correct. Post #'s 5,6,7. http://www.onlycubcadets.net/forum/s...ad.php?t=27733 |
Pto end of the crank.
That's fixable though. Turn it down, or swap cranks.
| Thread Tools | |
| Display Modes | |
