Old 01-06-2014, 11:27 AM
j4c11's Avatar
j4c11 j4c11 is offline
Default Cub Cadet 1450
Hello,
I've been lurking around for a while reading and trying to make a decision between buying an older machine or a new John Deere/Craftsman etc., yesterday I pulled the trigger and bought a new to me Cub Cadet 1450. The thing is built like a tank. Everything seems to be working well, I have one concern that maybe the Cub Cadet gurus here can help with. When I press the brake pedal the speed lever moves to N as expected,but the tractor starts to very slowly creep backwards. If I release the brake,and with the lever in the N position,the tractor does not move.Press the brake pedal all the way and it starts to creep backward again. Any advice on how to resolve this issues?
TIA
Old 01-06-2014, 12:21 PM
MinnesotaCadet's Avatar
You made a good choice. You wouldn't have been satisfied with the craftsman because they are notorious for blown engines and newer john deeres are just crap, everything is made of plastic. I have a 1450 and I love the Hydraulic lift, it makes lifting heavy implements a breeze. As for the hydro I think you may just need to adjust it by taking off the inspection cover. The older hydros are know to do that. It does that on a lot of my tractors. I'm sure more people will have information to help you. You can ask any question about your tractor and someone will answer.
Connor
Old 01-06-2014, 12:38 PM
Welcome to OCC! You did great on your 1450. Good to see another NC member! Where are you located? I'm near the Fayetteville area.
Old 01-06-2014, 01:00 PM
j4c11's Avatar
Thank you for the warm welcome! I am in the Triad area, got the tractor all the way from Eden but it was well worth it
Old 01-06-2014, 02:43 PM
bluesman bluesman is offline
Thumbs up
Originally Posted by j4c11 View Post
Hello,
TIA
There is a process for dealing with hydro creep that is explained in the chassis service manual. I did it on my 1650 not hard but harder to explain than to do. It may also be explained here on the site in the technical section. Welcome to the yellow fever and have fun with your 1450
I will attempt to address my procrastination problem while you wait.
Old 01-06-2014, 03:50 PM
congrats on the 1450 welcome to OCC
Old 01-06-2014, 04:08 PM
j4c11's Avatar
Thumbs up
I will check out the manual thank you for your help!
Old 01-06-2014, 05:24 PM
Welcome to OCC!
Congrats on the 1450!
Old 01-06-2014, 05:32 PM
sawdustdad's Avatar
Welcome to the forum!
You picked a great Cub. Yes, there is an easy adjustment to the hydro "neutral" that involves loosening a couple bolts on the hydro that holds the control plate and tapping it up or down a TINY amount, like a mm (1/16 inch) to get the tractor to sit still. You need the manual in front of you, looking at the tractor, to figure it out, but it's easy once you see what needs to be done. You MIGHT, first time, take the seat and rear fenders off to do it, it will give you much better view and access. Besides, it will give you a chance to clean things up under there--stuff has a way of piling up under there!
Old 01-06-2014, 05:33 PM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Welcome to OCC.
You made the right choice !!!!!!
Stopping the creep is not tough.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
