#21
Did you measure the belt that you have? Maybe it's not 28".
Edit to add: I just measured a 3/8 x 28 Gates belt and pulled tight it is about 13.5" on the outside. That belt fits my qa36. |
#22
![]() Quote:
Chris 1968 Cub Cadet 105 |
#23
![]() Quote:
Jeff |
#24
![]() Quote:
-Ryan
#25
![]() Quote:
I can weld a nut on the end instead of the handle so a 3/4" wrench or socket can be used. ![]() |
#26
Thanks Jeff but I the nut on my QA plate was right handed threaded to match the adjuster I had as well, I wouldn't be able to use this without swapping it that out.
Flattened my belt out, it's about 13.5" on the outside as well. This is it sitting at rest, with slack on the belt and out of room for adjustment. ![]()
#27
![]() Quote:
-Ryan
#28
![]() Quote:
![]() A shorter belt would work. Did you run the belt on there yet? If not, you may be able to return it . I could make a right handed version of the tensioner for you if you want. Entire assembly or just the left handed screw ? |
#29
Actually...mine is right handed
-Ryan
#30
I can make the screw right handed. Can you get me the overall length from the handle ( where the rod starts ) to the end of the threaded rod?
Thread Tools | |
Display Modes | |
