Old 01-09-2014, 08:06 PM
jimbob200521's Avatar
I can make the screw right handed. Can you get me the overall length from the handle ( where the rod starts ) to the end of the threaded rod?
I will be happy to get you that info but tonite, the thrower and I aren't on talking on terms. I was cleaning up some sidewalks at work today and as I've found before, this weather has made several sidewalks heave pretty bad. Well...I found another one today. I hit it so hard (was cruising at almost full speed with the thrower apparently not all the way up) that when it caught, I almost got knocked out of the seat. Anywho, it knocked the thrower a bit off of the quick attach mounts so I've got some work to do and when I do it, I'll get the info.
Long story short, yes I'll get you the length but not tonite
BTW, I didn't mean to jack this thread!
-Ryan
Old 01-09-2014, 08:26 PM
Get your working first and then if you have time, get measurements.
Sudden stops can really hurt
Old 01-15-2014, 02:32 PM
rdehli rdehli is offline
my QA42 A looks just like that , think my problem is that the adjuster is a little worn , its 35-40 years old and it just works loose. thinking of fabing something to hold the t handle in place so the belt will stay tight. Any body ever done this . thought I seen once where a guy drilled a hole thru the t-handle attached a short chain to the t-handle the bolted the other end of the chain to the blower mount. thoughts on this?
Old 01-15-2014, 03:37 PM
Rob, Do this....drill and tap a 1/4" hole near enough to the adjuster handle so that a 1/4" bolt threaded into o=it will catch the handle should it try to back off. Add a jam nut so you don't loose the bolt.
If you need to re adjust, just back off the jam nut, unscrew the bolt and adjust.
Dave
Old 01-19-2014, 11:53 AM
Originally Posted by cmouta View Post
Is the adjuster supposed to look like this?
that IS reverse thread and that castle nut makes sense because there is a hole for it which is not the case with the adjuster I have. I'm starting to think I got a little hosed on this snow thrower from craigslist. The belt I was given was too big, the lifting rod was too short. now this...
I purchased material, I have begun machining and will be offering these shortly.
Jeff
Is there a way to incorporate some kind of socket head on it to make it able to be turned with a wrench? Even a nut to put a socket on or even a female socket adapter (like the fill plug on older Cub rear ends have) would make it easier to get to from time to time. Just a thought, looking forward to seeing what comes out of your shop!
Got the first few done
QA36 / QA 42 / QA36A / QA42A belt tensioner bolt, castle nut & plate button . This style has a welded nut in the end for use with 3/4" wrench. ( original style will offered later after I bend up handles)
These are 1/2 -13 LEFT HAND thread
I'll also sell just the bolt and castle nut too
Complete unit as shown $27 plus shipping
Adjustment bolt with castle nut $15 plus shipping
Plate button $15 plus shipping
I put this in my parts for sale post too.
Old 01-19-2014, 01:50 PM
Muzzy Muzzy is offline
Nice job Jeff.
Old 01-19-2014, 02:22 PM
Originally Posted by Muzzy View Post
Nice job Jeff.
Thanks Muzzy
I'll update the pictures, I got larger washers and cotter pins.
Old 01-19-2014, 10:14 PM
Great job as always, Jeff!
Old 01-26-2014, 06:50 AM
yeeter yeeter is offline
I like the idea of being able to put a wrench or socket on it to adjust. In fact, on one of the ones I have the PO welded a large nut to the adjuster wing - just throw a socket on it and can turn it to however tight you want.
