Old 01-26-2014, 02:35 PM
OldAndInTheWay's Avatar
Default How do I get the pulley (the one with the screen attached) off My O?
I need to replace a pulley on my O 7hp.. The one that runs the drive belt. I have all the fasteners that hold the shroud on removed and the crank shaft nut off. I cannot get the pulley with the screen off for the life of me. It has to come off so I can remove the shroud. The pulley needs replacing also. Anyone have one? The pulley that is. I have it listed in the wanted section.
Thanks
John
Old 01-26-2014, 02:42 PM
cub123's Avatar
cub123 cub123 is offline
They have a small pin that goes in the flywheel that usually sticks, typically a few hits with a rubber hammer or something loosens them enough to pull it off.
Old 01-26-2014, 02:57 PM
Just where would this pin be? I have looked at the pulley, down where the nut holds it to the crank and all along the outside of the pulley and I don't see the pin you are talking about. Could it be behind the screen? If so, how would I get to it? Is the pin attached to the flywheel? I have looked at the pulley real close and I am still at a loss.
John
Old 01-26-2014, 02:58 PM
Is the pin part of the pulley on the back side where it rest up against the flywheel? And locates the pulley?
I have been bopping it with a brass hammer while pulling and I doesn't want to budge.
Old 01-26-2014, 03:09 PM
Got it off. Thanks, you really helped. Now that it's off I can see how it fastens to the flywheel..
Now all I need is to find a replacement. Any Ideas?
Thanks
John
Old 01-26-2014, 03:24 PM
cub123's Avatar
Glad I was able to help, happy to hear ya got it off For a replacement you might want to try the sponsors at the top of the page, or wait a little while and see if you get any offers in the wanted section, I got my replacement from a member.
Old 01-26-2014, 03:36 PM
cadzag72 cadzag72 is offline
Check with Chris Westfall, I was able to get a screen and pulley for my 125 from him and it was in great shape. not the same as an original, but he's great to work with.
Ian
Old 01-26-2014, 03:59 PM
I have worked with Chris before. I will give him a shout.
Another reason to sometimes take these machines apart. Mud daubers had completely filled up the spaces between the fins on my Kohler. That is some tough mud!
