put external brakes on it.Then split the brake pedal pad in half so that you have individual rear wheel brakes when you want them. With chains on, you will have pretty good turning brakes. |
I would like to do that, have independent rear brakes.
No. Not unless you speed up the entire trans.
Is there a way to make a hydro go faster in reverse?? I dont know much about hydros but with the swashplates the way they are it seems it should go the same speed in reverse as going forward? Does the linkage limit it or am i just wrong? Havent really dug around much in there...
You could grind the nub on the swash plate to allow it to pivot more in reverse. Wouldn't be too big of a task.
Or did you mean on the internal swashplate? If so, that is not a good idea. Besides, then you would have to make the slot in the dash longer. NOT worth the work of disassembly. |
Flip the rear ring gear and you can have 3 rear speeds and one forward....yehaa
Sometimes it's the cool ideas.... ![]()
Leave it to Lew!
| Thread Tools | |
| Display Modes | |
