Old 02-15-2014, 08:28 AM
MWShaw's Avatar
MWShaw MWShaw is offline
Turn around and wind-row it over one pass so you aren't wasting time. Or buy a blower.
He does have a blower, as a matter of fact I think he has (2)! I just dropped a QA36A off at the Fastenal store, and it is headed for South Dakota? I think that ones going to be a donor for his other one.
But I have a dozer plow and blower fro my 782. The dozer is fine for when you have a small amount of snow, but the way it's been piling up around here lately, the snowthrower is the only way to go.
Even if I had a plow on my truck, it is getting dificult to find places to push the piles to. The driveway that goes to my shop, would be very dificult to do with a plow truck. Just no room for this much snow.
But now that I have my H42 and cab on the 782, it will probably be 60 deg next week!
Old 02-15-2014, 08:39 AM
MWShaw's Avatar
This was earier this year, the day I took the dozer blade off, and put the QA36A on;
You can see that was a full load on the blade, if you angle the blade and try to windrow it, this deep heavy stuff just pushes the front of the tractor over, opposite of the angle on the blade.
And none of that has melted, we have only gotten more since then.
Old 02-15-2014, 01:42 PM
Skinny wheels and tires.
That is a lot of snow though...
Old 02-15-2014, 04:23 PM
Nice pics of the 782 with thrower and blade! That's usually how it goes to, get the tractor set up how you want it and it will be 60 next week!
Old 02-15-2014, 10:02 PM
Gonna be in the 70's here, buddy!
Old 02-15-2014, 11:00 PM
sawdustdad's Avatar
It won't help much (if any). The casting on the internal swashplate won't allow for more travel. It has a "nub" on it that hits the case at full travel.
Or did you mean on the internal swashplate? If so, that is not a good idea. Besides, then you would have to make the slot in the dash longer. NOT worth the work of disassembly.
Yes, I meant the internal swashplate. Maybe you could trade max forward speed for more rear speed with the same dash slot?
Old 02-15-2014, 11:35 PM
Oh, I suppose you could..... this has been debated here before. I am very adamant, that unless it is completely necessary, to not disassemble a hydro. The internals are more sensitive than any internal engine part, and really shouldn't be messed with. There really isn't any gain. Not to mention the safety issue of neutral not being in the neutral spot.
Old 02-16-2014, 10:55 AM
hdsdcouple's Avatar
I solved my faster reverse problem. Sadly, solving the problem doesn't involve a cub cadet.
thanks for your help guys
Old 02-16-2014, 08:26 PM
MWShaw's Avatar
Do tell? What did you come up with, a house in the Florida keys? No snow to plow there!
Old 02-16-2014, 10:05 PM
sawdustdad's Avatar
I would agree that messing with the swash plate would be a desperate measure. Disassembling the hydro, however, is not particularly difficult, as long as you are careful and meticulous. I've rebuilt a couple and they run better now. The new trunnion and springs makes a world of difference in how the tractor operates.
