I was wondering, before I break down and order one, if I were to get a Cat 0 3 pt., will I be able to hook my 1A tiller up to it? I realize that I would need a longer belt from the gearbox to the tiller, that isn't a problem.
Jim Bridgewater, KD0FJO Osage, IA 1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow |
no. the tiller attaches to the gearbox frame and uses the tractor's lift to raise and lower the tiller. you can attach the 2nd and 3rd pt of the "3 pt" to the tiller gear box frame and then attach a sleeve hitch to that.
there is some usefull information in the tech lib. http://ccmanuals.info/pdf/1A%20Tiller.pdf tiller.JPG tiller2.JPG
100(2) 128, 129, 76(1/2) |
I guess redwaycc has never seen the Cat-0 adapter package for the tillers.
I started reverse engineering the kit. See this thread: http://www.onlycubcadets.net/forum/s...ead.php?t=3472 |
no Matt G. i have not seen one nor have i see one for sale either. will you post that link too?
Is that the 3pt from Xtreme Motorworks?
bridgewatertek- No, it is the OEM 3-point (the xtrememotorworks version is a copy) mounted on my 782D. The really nice thing about this is that the gearbox can be installed or removed in a couple of minutes. I still have to find the right length belt and make the linkage that connects the 3-point rockshaft to the tiller to lift it. |
Might I add that this is for my 1450, which didn't come with an OEM Cat 0. What I am thinking is bolt the gearbox directly to the 3pt and use the 3pt to raise and lower the tiller instead of the rockshaft. The main thing I am wondering is if you guru's think it would be plausible?
So my my best bet if I wanted to add the 3pt from Xtreme would be to bolt the tiller frame and gearbox assembly to the 3pt back plate?
You'll actually need to come up with something like I did, or find one of those kits. Notice how far down the gearbox is mounted on mine. There will be nothing to bolt it to if you try to bolt it directly to the plate.
| Thread Tools | |
| Display Modes | |
