Old 03-03-2014, 01:54 PM
Default Tandem disk on a sleeve hitch
Just got me two disks, and I arranged and bolted them together to make a tandem. Just did it to see how heavy they would be. Plan to make the two frames into one, and put it on 3pt. (The cat 0 Brinly disks are too hard to find). Anyone running a tandem on a sleeve hitch? I wanted it have both a cat 0 hitch and the Brinly on it, but, man..... breaks my arm lifting the silly thing! Yes, I have spring assist, but I think it may just be too much. Flexing the adapter an awful lot. So.... anyone else have tandems on sleeve hitch?
Old 03-03-2014, 03:24 PM
I think I would rather pull a single gang, with extra weight in the weight box, for a garden.
The dual gang with weight in both boxes would be great for a field, where you do not need to lift the gangs, just keep on going!!
Either way, the discs need weight to be effective, in most soils, single or dual gangs.
If I were going to gang them for a 3 point, I think I could consider wheels in between the gangs, 3 pt operated, of course.
Then the wheels would be your weight, and the lift would be located where it would do the most good.
JMHO
Old 03-03-2014, 09:51 PM
Nice find, Jonathan!
Old 03-03-2014, 09:55 PM
JMHO
I think you are probably right. It is going to be a 3pt disk, but I know I've seen pics of tandems on sleeve hitch, but they may not have been these. They are both pretty heavy! No biggie. I was planning on having depth wheels on it when its done. Like I said, this isn't the way I'm going to run it...... I just wanted to see if I could lift it!
Thanks Allen!
Old 03-04-2014, 01:20 AM
Extra bowl of Wheaties in the morning.
Did you get my email Saturday?
Nice tandem by the way.
Old 03-04-2014, 05:58 AM
Nice tandem setup Jonathan!
Old 03-04-2014, 06:29 AM
Nice tandem Jonathan.
Old 03-04-2014, 09:51 AM
Is the one behind the brinly some other manufacture?
Looks like an Ohio steel one.
Old 03-04-2014, 10:30 AM
Leadslingingdaddy's Avatar
Like this???
Old 03-04-2014, 11:14 AM
Todd, Mike, and Nick, THANKS!
Lew, I do not know. I have found pics of the early Brinly disks that look just like that. But, the Ohio Steel ones did too. To me, it looks heavier than the Ohio Steel ones. There are no tags on it. The front one is definitely a Brinly.
Randy, YES! That's what I want. Just can't find one. Maybe someday!!
