Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 03-31-2014, 09:13 PM
Default K341 intake valve noise
I got a question about a K341 intake valve. I just got my 1650 running today and noticed a very loud noise coming from the valve train. I pulled the valve cover off and notice that the intake valve, when it is fully lifted, will make a loud "pop" noise before coming back down. Otherwise the valve seems to move fine. I sprayed into the guide to lubricate it and it doesn't seem to help. Should I try a different valve? Broken spring? I looked at the lobe through the fuel pump hole and it looks fine. Any thoughts?
Old 04-01-2014, 12:43 PM
Pull the intake valve and clean it and the guide really good. Sounds like the valve is sticking at the full open position then snapping closed. So, a sticky intake valve.
