Old 04-16-2014, 05:42 PM
200 allis's Avatar
200 allis 200 allis is offline
Angry Narrow frame clutch driver
So I am putting in a new clutch from midwest super cub, and I was going to take the three pin driver off to check the bushing. I removed the four bolts and tried gently prying on it but it will not move. Has anyone had this problem and is there a secret on how to remove it without tearing up the flywheel screen?
Marshall
Old 04-16-2014, 06:32 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
sometimes gentle don't work. you have a steel clutch driver and an aluminum cup. you could try some heat on the drive cup , might help
Old 04-17-2014, 04:29 AM
cubby102's Avatar
cubby102 cubby102 is offline
Ive always had luck using a rubber mallet. Just kind of work it back and forth. Some pb blaster helps also
