It ran ok but sure liked to smoke, and a little down on power. About two, three years ago it swallowed up a carburetor screw. Made it out the muffler but not without a little damage.
Well this NOS 14hp Command came up on CL for a very good price. It was a pull start engine so I needed to change everything over from the 12.5 electric. First hiccup was that the stator mounting holes were not tapped, and two were missing so I needed to drill two holes and tap four, pretty easy fix. Needed to take the fuel pump off the 14 because it would interfere with the muffler, that I needed to use from the 12.5 to clear the hood, then make a plate cover for the fuel pump hole. Mount the ring gear flywheel and starter, I also reused the flywheel cover from the 12.5. (sleeper) It fired right up ![]() ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Sounds like a nice little project Todd.
Looks good Todd and nice pickup on the engine!
Good score, Todd!
Good goin Todd!
Man you take good care of your tractors! No dirt, oil or mess on that one anywhere!! You need to sweep the floor though. ![]() ![]() ![]() |
Looking good Todd.
![]() Quote:
Pressure washed it after the engine was out. Yeah, I know the floor was dirty, windy day and all the crap from the trees blew in. Thanks guys. Had it out mowing the lawn today. A lot more power than the old worn out 12.5, but still took 4 hrs.
![]() Quote:
Very cool, I have a 12.5 command and a newly aquired 14 command with fuel pump labeled as a craftsman but came on a murry frame (both mowers free). And the 14 probably needs carb cleant but it runs on spray
122 PTO, lift, deck, weights, and chains clist pick 123 headlights no motor came with the 122 Stx38 free acquisition but its the wrong color works great though Free craftsman gt 17hp Briggs Intek hydro |
Thread Tools | |
Display Modes | |
