Old 05-26-2014, 10:19 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
I would remove the rear cover. To be honest I stopped using gaskets on the cover. I not use ultra grey sealant on them. It is the same stuff cummins uses on there engines because they don't have gaskets on some parts. As long as the surface is clean and dry it works fine. The only problem I have had is sometimes it leaks when you put a tiller gearbox on. Check for metal when you drain the oil.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 05-27-2014, 10:11 AM
dbuck dbuck is offline
Smile
You can buy gasket material at NAPA, and make your own. I too would pull the cover. After draining, raise the front of the tractor and flush out any residue with brake clean. Then refill with IHC Hi-tran, should be 7 qts. As far as the filter, I would change it too.
Old 05-27-2014, 02:04 PM
To answer the question, it's VERY important to get all of that garbage out of there. No sense doing 1/2 the job and wasting your money. Personally, I'd put another new filter on it too.
That's exactly what I do but I'm too lazy to lift the tractor in the air and just use my fluid gun to suck out as much as possible and then finish with a rag. I use the fluid gun to fill it too so it's already out and going to be dirty anyhow.
I'm also too lazy to make gaskets unless I have to so I buy them from Cub. There's nothing wrong with sealant as a gasket, I just personally don't like doing it (personal preference). The next one I do I'm going to do like a valve cover gasket (hi-tack one side of the gasket and glue it to the cover, then grease the other side before installing) and see if I can get away with reusing it a few times.
Old 05-27-2014, 03:03 PM
Go buy some permatex ultra black, it is without a doubt the best silicone on the market but don't use to much or you'll have to destroy the cover to get it off next time.
Old 05-28-2014, 06:55 AM
Smile
I have a chain fall in my shop, so no problem lifting anything. Maxwelhse, what CC dealer do you use around the Fort? The old grease trick, learned that many moons ago from my Father and Grandfather. I also use red hi-tack on some gaskets. If I hi-jacked this thread I apologize.
Old 05-28-2014, 07:06 AM
Smile
I have a Buddy that use the ultra black. He has the mind set that more is good, therefore he wastes most of it and usually has it over all his hands and what ever he is trying to seal. Its a wonder with all these new sealers in recent years, how we ever got by with number 1/2 permatex back in the day?
Old 05-28-2014, 11:25 AM
Nitro's Avatar
Nitro Nitro is offline
#2 permatex is still my favorite, thin film of it does the job.
Philip
1450, 1015, and a pile of parts.
Old 05-28-2014, 01:33 PM
That's why I don't like it.. Few people do it right and I've had to clean up too many messes made from it. When I see RTV on a part I immediately dread taking it off (which can be a nightmare) and then finding whats under it.
Myself and other know how to use it correctly, but it just makes me sad... So I don't do it.
Old 05-28-2014, 02:59 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I prefer to use bubble wrap. I like the sound it makes when you tighten the cover bolts up. it usually leaks but I still have fun every time I reseal one. and once in a while it works. so a good time is had by all
Old 05-28-2014, 03:01 PM
That's the best! LMAO. Wonder if you could use bubble wrap instead of plastigage when you check a rod for clearance? The more pop's the tighter it is?
