Well you guys sorta win as you were the closest
![]() Well Sam, I hope you consider this a good machine, although I doubt it stands up to one of your Supers I've seen pics of ![]() BTW Sam, I'm ready for the critiquing/suggestions from the Cyclops guru for what I need to check into! lol So guys, as much as I would have loved it to be an 1864, I'll have to settle for this guy. She's in good running shape, although she will need a bit of TLC before she's in tip top running condition. The engine is in great shape, no smoke, sputtering, doesn't burn oil, no weird noises, etc. The trans doesn't make any weird noises but I still plan on changing fluid/filter asap. Also, it will need the linkages adjusted because as it sits, things don't allow it to get to top speed right now. Other than that, PTO works fine, wiring seems decent, I don't see any fuel or hydro leaks so it's got good potential. Anywho, on to the pros/cons as well as a few pics. Hope ya'll approve! Pros: Machine only has 459 hours on it Solid engine. No smoke and fires right up Plastic panels are all in pretty good condition, save one crack in the hood Deck spindals are all in good shape, spins easily and freely Cons: I'll have to re-run the fuel line as some stupid a$$ PO ran it outside the fenders. WHY?!?! (you can see it run by the brake pedal) ![]() Hydro linkages need adjusted as she doesn't get up to top speed in forward or reverse Couple good scratches on both sides of the fenders Steering is a bit loose Anyway, on to the pics! ![]() ![]() ![]() ![]() ![]()
-Ryan
Alright guys, I've got a few questions about the new toy. Please bare with me as I haven't had really any time to do any in depth research so some of these may be easy ones.
1) This is my first CH motor. Can I remove tins without pulling the engine to make sure there's no mouse nests tucked away? 2) Is there a service manual posted anywhere for this? I took a quick look in the technical section but didn't see it. 3) How would I go about adjusting the hydro linkages to get full travel? With the lever full up right now, I can't get much past what I consider mowing speed. 4) Is the steering box similar to the ones used in older Cubs? I'd like to get the slop in the steering taken care before it gets bad. Thanks guys, and wish me luck with the new toy! ![]()
-Ryan
I thought for sure you went after this Super right down the road from you
![]() http://rockford.craigslist.org/grd/4508520080.html |
![]() Quote:
-Ryan
Ryan, I have the engine SM on PDF. I can send it to you when I get to a pc. PM me your e-mail.
What are your plans for this one Ryan? I'm thinking the steering box parts are the same, I seem to recall reading that the bearings and I think the cam follower pin are the same part number for my 782 & 1861. My 61 has a really loose gearbox too but I've been using it too much to take it apart. After fixing all the tie rods & the front axle clevis on the 82 it really isn't bad. I have the parts sitting here to overhaul a steering gear...... I just haven't found the proper motivation yet.
Enjoy the new ride...
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
Congrats on the 1863 Ryan!
![]() Quote:
![]() Quote:
-Ryan
Majority of shrouds can be removed w/o pulling the engine. But pulling an engine in your case wouldn't be very hard. Would allow you to degrease everything/ pull the drive shaft to inspect, clean, and re grease, along with making a lot of other things, including your steering box more accessable. You got a good machine and far as I kno, the main differences between the 1864 &1863 are power steering and the hydro pump. 1864 uses a sunstrand, 1863 uses a hydrogear. Good luck!
That's right, it does use a HG hrdro. I forgot that.
Thread Tools | |
Display Modes | |
