Old 03-11-2010, 12:05 AM
johncub7172's Avatar
Default K161 Governor setting
I'm trying to figure out how to set my governor. It seems to be more difficult than what the book says. the motor runs fine, but i cant hook up the throttle bracket to set the rest. please help!
Old 03-11-2010, 12:08 AM
young enthusiest's Avatar
Pictures would be very helpful. Can you please try to explain a little better what you mean by "set the rest"? What have you done to it so far? What exactly are you haveing trouble with? If you give us some more info, maybe we can help you.
Old 03-11-2010, 11:23 PM
thank you for the reply. i shall have picts. up tommrow afternoon. i've been monkeying with the gov. i was not thinking and removed the gov.arm to paint. the kohler manual does not say at all how to set the throttle bracket so it stays mounted allowing my throttle wire to operate the speed control disk. i also have the blue ribbon for thie motor and it is about as dry as reading the dictionary.i'am making good progress on trying to figure it out. i love these old tractors.
Old 04-16-2010, 12:15 AM
well so far the govoner is working but not a lot of throttle. I took it to the chainsaw shop today and back. When i started out in 3rd. gear, the gov. seemed to pick up torq. I'am guessing that the throttle bracket is not set correctly, the speed disc rides on the back side of the brass nut,[around the stem-part of the brass nut.] And i believe the throttlebrac. is forked to the gov.shaft. I have the t.controll cable in the correct hole in the speed dics. And about the pin in the S.D that stops at the throttle bracket. Its not over reving, but backing off the gov. shaft and dropping down. Could be that the gov.arm needs re.adjmnt? But to tighten up the brass nut is a challenge, but too tight and the shaft dont turn. After it warmed up good by going to the shop, is when i could see the slack in the gov. setting. i still can get a pict. up of the old 7hp. to show where it is set at.
Old 04-17-2010, 01:34 PM
Well, I found section 6 Fuel System And Governor in the Kohlerengines Single Cylinder Engine Service Manual K-Series. So will give this try and move on to the speed setting and check. Cool! Looking good so far.
Old 04-26-2010, 12:40 PM
Well, I've made good progress on this adjustment! Now all I need to do is make a "z" bend in the throttle cable which operates the speed disc! Nothing to it!
