Old 07-20-2014, 09:00 PM
1650noob 1650noob is offline
Originally Posted by rpking View Post
looks like you just need to replace the button on the linkage arm that presses against the pto when you engage it
you don't have to remove the pto to replace that
Hello,
I wish I could do that, but I have to replace both buttons. The wear button got shaved down and looks like a corkscrew.
-Nate
Owner of:
cub 1650
cub 122
Old 07-20-2014, 10:09 PM
Try grounding the tip down on the PTO button to make it smooth. If you have a right angle air die grinder or a Dremel tool that would work good. I think it looks good otherwise. Put your brass button on and continue use. Just a suggestion.
Old 07-21-2014, 01:10 AM
I agree that button doesn't look bad at all.
Start the engine and use your angle grinder with a fine, flap wheel on it and just touch and polish the button.
