Go Back   Only Cub Cadets > Resources > Technical Library - Tractors > Technical Tips
Closed Thread
Old 07-23-2014, 08:25 AM
jimbob200521's Avatar
Great write-up John! I was beginning to wonder where these went
-Ryan
Old 07-23-2014, 10:12 AM
Thank you boys!
Ryan, I've just been busy. Summertime you know. Lots to do!!!
Old 07-23-2014, 05:45 PM
PaulS's Avatar
PaulS PaulS is offline
I fully agree, another great writeup but for a mechanic your hands are just too clean. Lol
Old 07-23-2014, 06:21 PM
Good mechanics don't get dirty. We work smarter, not harder.
Plus, I have some REALLY good hand cleaner!
Old 07-23-2014, 06:55 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
probably one of those rubber gloves guys. and probably likes to snap them when he puts them on. like a doctor. just so you have to turn around to see who's there and what's going on.
Nice write up Jon. but how do I get that bottom screw out? and then that rubber seal on the points wire? you know the one? eh, do I need that? its all hard and don't like to fit back in the cover. and do I need the key on or off? does the clutch pedal need to be depressed? do I take it out of gear? if I leave it in gear the whole tractor moves when I roll the engine over. is that normal? I was holding onto the plug wire and got a shock. it hurt and then I had to pee. is that normal? some days I get so confused. is that normal. when I set the timing is it ok to spill a gallon of gas all over everything because the can I have holds 2 gallons and the tank only holds 1 for some strange reason?
but seriously it is a nice writeup
Old 07-23-2014, 07:10 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Don, That sounds like an enlarged prostate. You may want to see a doctor, or leave that plug wire alone!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-23-2014, 07:23 PM
Don, you are the best!! Now I have to pee!!!
I had a crappy day. I feel a little better now!
Closed Thread
