![]() According to the Kohler manual, shut down is best done at 1/2 to 3/4 throttle. I've experienced the "hard to shut down" problem where it almost seems to backfire but if you shut down at at least 1/2 throttle, it shuts down like a dream. This is what I've been doing and so far, so good
-Ryan
You boys go ahead and shut your engines off however you want.
![]() If everything is set like it should be and working properly, it won't diesel, and it won't backfire. It's not an opinion, it's a fact. |
Disagreeing with me is fine...... just remember, I've worked on a few more engines than you have. You may have good luck this way, and the manual may state that, but I'm not shutting my motors down this way. If set right, they will shut off at idle. **EDIT** That said: The main reasons for a motor "dieseling" when shut down are; *Fuel solenoid not killing the fuel *Motor is still too hot, needs to idle longer and cool down #1 reason.... low idle is too fast. Set the low speed lower. |
As far as I'm concerned, all is well that ends well
-Ryan
Grandpa always said to let the EGT on the 1086 get below 300 before shutting down. Had that drilled in my head at 7 yrs old. Its carried over.... to everything. Idle for a few min and put it to bed calmly. I don't go run a mile and fall asleep right after!
Just wanted to contribute
You responded before I changed my post. See my edit on post #13.
The EGT thing is VERY true! I love your analogy, I have used the same one on here more than once!! An engine doesn't like to be shut off right away after a "hard run" any more than you would run a mile in a dead sprint, and then just lay down at the finish line.
I run mine wide open to cool down with no load, then idle for 10-15 seconds and as I am turning the key off go to WOT. That is how the PO advised me to do it and I have no backfiring if I do it this way. My 1864 halfway on the throttle is still idle so even the supplemented way goes boom.
Sorry the compressed pic is hard to read but the original manual says shutdown from SLOW setting and the supplement says halfway between SLOW and FAST.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Wow! All this just to shut off an engine, I'm impressed. Not trying to stir the pot. Just my observations with back firing or dieseling Commands. I've had some that as long as I let them cool off for a minute or two were just fine at idle, some liked 1/2 throttle, one I had to pull the choke and turn it off at the same time. I don't think that the shut down solenoid instantly shuts off the fuel, reason I say that is if you try disconnecting the kill wire to the mags and then shut it off it will run for a short while before it actually runs out of fuel. I have a neighbor with an MTD that has a CV20 in it, she insists on turning off hot even though I have told her not to do that repeatedly, still can't figure out why the muffler hasn't blown out. See what works for you is my suggestion. If you can get it to behave at idle that's always the best.
![]() Quote:
![]() Problem is my zero turn has a 26 horse Kawasaki. Uh oh, a different can of worms...............
Josh Diesel Cub Cadets........... |
| Thread Tools | |
| Display Modes | |
