Sam mac I've had plenty of diesel experience. From tractors to trucks. You are right and wrong, you can indeed spritz fuel through the intake to get them to run. Had a Ford with a 3208 cat and that was the only way to start it on a cold morning. Also had a Yanmar tractor that you would have to do it too if it was hot and you went to restart it. Oh and had an 85 chevy with a 6.2 the fuel pump was weak and wouldn't build the pressure to fire, a squirt in the intake and she was off to the races...
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
I still think you may be in for $$$ repairs, but maybe your one of those "lucky" guys. May just be bad glow plugs. Good luck.
If you say so. Guess I know nothing about diesels.
So starting fluid in diesels isn't supposed to work? Hmm you've caught my attention. I want to know more!! haha
![]() I ask because the farm I work on, the old Ford loader they use for snow moving is a cold/slow cranker so the farmer keeps on a can of starting fluid on it (for use during the winter only). If that's now what is making it fire off, I'll stop using it!
-Ryan
Here are some pics of the pump / no pump. Jimbob, read the link I posted. Pretty scary stuff.
A diesel won't run off ether alone, there has to be some diesel fuel in the cylinder or its a no go.
-Ryan
Oh, yes they will. If you use enough. Done it.
| Thread Tools | |
| Display Modes | |
