I've used Raptor liner, Herculiner and some of the rattle can stuff.
I like to keep em running and work them. 1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors. |
I used dupli-color spray bed liner on my 125 foot rests, and they've both held up to constant use showing no wear and been very functional, having good grip even with snow and water.
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors!
I have used duplicolor ratle can and rustoleum rattlecan, as well as spraying duplicolor, gator guard, some 2 part epoxy stuff i cant remember, and the SEM black bedliner stuff (the cheaper of the two options they made at the time) the rustoleum and duplicolor do fade faster. My best experience was with SEM. Pretty durable for a urethane.
I did a horse trailer about 18" up inside and out with duplicolor, a utility bed and a pickup bed with gatorguard, and 3 pickup beds with SEM. Duplicolor came out nice, but ages fast. Gator guard had a sandy additive in it, it was a pain, and I didn't like the final finish. For what it is worth, I used the schutz style gun and hated the amount of time it took. I switched to a texture gun (used for shooting texture on walls and ceilings) it gives better control over the texture (fine to "pebble") and the hopper would easilly hold a gallon of product at a time. If you go this route, go buy the cheap $20 one from harbor freight. It worked great for me, and even though i never have the two part urethane set in/on the gun (I cleaned up pretty quick when i finished) it would not have been the end of the world. As cheap as the hopper gun was, I would not consider rolling. Regardless of what you do, prep is key. Start with clean paint, scuff it (I used a sandblaster to etch the paint,) remove the dust and wipe down the whole surface with laquer thinner. As soon as the thinner evaporates, start applying your product. I would spray a "coverage coat" on the whole surface then build and finish on that, all in one spraying, not letting it dry first (maybe start to tack). IF YOUR PRODUCT SAYS JUST ONE HEAVY COAT, THEY MEAN IT. Don't ask how I learned, it was not pleasant, and I did not use that product again. |
| Thread Tools | |
| Display Modes | |
