Old 08-12-2014, 06:08 PM
o---o o---o is offline
Default I love my Cub, but HATE the deck!
I love my old 1541, but absolutely hate the 46" deck hanging under it. If the grass is even just a little bit moist it will clump up under deck and I have to stop often and clean it out by hand. Also after mowing, my yard looks more like a hay field. My neighbors all have new zero turn mowers and theirs seem to do a lot better job of "chopping" the grass into smaller pieces whereas mine seems to discharge it whole and it lays on top of the grass and looks awful.
I'd really like to have a rear discharge deck and have thought about building one. I wouldn't have to worry about blowing my cut grass into the neighbors yard and wouldn't have to worry about throwing rocks into my house or car, or worse, the neighbors house or car. I could use newer, readily available spindles and blades as everything I need now is expensive and needs ordered.
Old 08-12-2014, 06:12 PM
So do it.......
But remember.......
Old 08-12-2014, 06:21 PM
This is NOT a good thing, dulls the blades and leaves a poor cut.
Old 08-12-2014, 06:30 PM
timbo2's Avatar
timbo2 timbo2 is offline
What about gator/mulcher blades?
I haven't used them but they're probably available for your deck.
- Tim
Old 08-12-2014, 06:31 PM
I'm gonna sound like a smart a$$ now, but...... if your yard looks like a hay field after mowing....... mow more often.
Old 08-12-2014, 07:12 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I'll second that! I was also thinking about the grass clumping up under the deck. I wonder if the deck belt is in good working order... As if all the blades are turning?
Plow blade
#2 Cart
QA36 snowthower
Old 08-12-2014, 07:13 PM
See post #3 for that problem......
Old 08-12-2014, 07:26 PM
Billy-O's Avatar
I saw Post #3. Unless I misunderstand, I'll stand tall with my question asked!
Plow blade
#2 Cart
QA36 snowthower
Old 08-12-2014, 07:34 PM
I used a 46" deck for years on several different tractors. The only reason I don't use it any more is I found out how much better the 48"/54" decks cuts.
The only problem I had with the 46" was that it tended to windrow the clippings. I never cut the grass when it is wet and I don't try to cut that short.
Any rear discharge mower I ever saw looked like a hay field that had had a hay rake run through it. Your results may be different.
Old 08-12-2014, 07:36 PM
jimbob200521's Avatar
I agree BUT I will add; I have parts of my yard that grow faster, thicker, and taller than the rest. That leads to me to my point: keep your blades sharp #1, and #2, I think the older decks don't "flow" as well as the newer ones. I've had triangle decks, quietline/82 series a & c decks, and now gt decks. The biggest difference maker is good blades but the newer decks don't seem to clog as much. I've never had my 54gt deck clog but the 44c I had would if I wasn't careful if the grass was damp at all or very thick. Just my
-Ryan
