Go Back   Only Cub Cadets > Cub Cadets > Home Made > Plans, Drawings & Prints
Old 08-29-2014, 06:24 PM
IHinIN IHinIN is offline
Default Deck gauge wheel mounts
These are mounts I made for my 48" deck to mount spherical gauge wheels on all 4 corners.
Both rear mounts are the same.
Right front.
Left front.
Old 08-29-2014, 08:02 PM
bocephus1991's Avatar
Those look very professional! Good job!
Brian
Old 08-30-2014, 12:17 AM
Very nice job
Old 09-01-2014, 01:40 PM
Thanks guys. I've only mowed once with the deck but they work great.
Old 09-02-2014, 11:26 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Good job on those beefier and better load bearing brackets.
And I like the welded up end of the deck too.
Is that a replicated deck shell?
Or did you just save an O.E.M. deck shell?
Old 09-02-2014, 11:50 AM
It is an original shell. I had to repair a couple spots but it was otherwise in great condition.
Old 09-03-2014, 10:50 AM
Steve149's Avatar
Steve149 Steve149 is offline
Great job Adam...I was just wondering why the two front brackets are different measurements? Is this done for clearance purposes? I have a template made for the back two. I will be getting the deck torn down for a restore here as soon as my dozer blade is done then I can focus on the deck as it needs some long overdue TLC!!!
Old 09-03-2014, 10:57 AM
SGragg SGragg is offline
Inactive Member
Unless I missed it, how thick is the steel plate? 1/4"?
Nice professional-looking job! Glad they're working out for you.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 09-03-2014, 11:54 AM
Steve149's Avatar
I looked back thru the original post and yes it is 1/4" plate
Old 09-03-2014, 12:00 PM
DoubleO7's Avatar
I suspect the different front brackets are to accommodate the height growth of the deck because of the outlet.
And end up with the gage wheels in the same hole from the ground.
