Old 09-03-2014, 06:01 AM
Here is a simplified Start Circuit Diagram with the correct colored wires...
Power leaves the Battery Positive Terminal to the B terminal on Ignition Switch. When engaged, the S Terminal receives the power and goes to the C Terminal on PTO Switch. If in the off position, the PTO Switch will send power on to D terminal. Leaving the PTO, the power goes to the Neutral Safety Switch (Brake pedal) and finally on to the Starter solenoid.
If you have a meter this should be easy to trace down.
Old 09-13-2014, 11:10 PM
alsparl alsparl is offline
Well, I believe we figured it all out. Went though the testing and feel comfortable with the diagnosis. For kicks and giggles, I installed a solenoid from an MTD Yard Machine I junked out with a broken transmission case. Once installed the machine fired right up with no issues at all.
Now, the next question: the MTD unit was mated with a B&S and the 1/2 the cost of a new one listed for the 782 from the dealer. Would I be safe using this MTD Yard Machine solenoid on the 782 or would it be in my best interest to get a original part? The unit is simply gonna be the work horse so to speak.
Thank you all for your feedback and help on this issue.
Aaron
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 09-13-2014, 11:33 PM
as long as it works you should be fine, a solenoid is a solenoid.
Old 09-14-2014, 07:19 AM
Solenoids are rated by the "Contact Rating" (or load rating) based on amperage they will handle. For example, 40A, 50A, 60A & etc. These ratings are not stamped or lettered on the solenoid it self, so it is hard to know. In your situation, use the solenoid and if it burns up, buy one for a Ford.
Old 09-14-2014, 03:32 PM
Thank you both for your messages.
Roland, Very interesting about the Ford solenoid as I was unaware of that.
It would be interesting/neat/beneficial if the board and it members could create a "cross over" page, so to speak, about any and all parts that have a common auto use or placement compared to a specific use for Cadets. I think we know genuine MTD parts aren't the cheapest but may certainly be found cheaper in the auto application.
Thank you all once again.
Aaron
'83 782 #723927
'04 SRC621
****spec 24646
****s/n 2507913316
Old 09-14-2014, 03:47 PM
I think if you take the time to contact a parts store, your will find that they have books that do just that. I don't know why so many people have trouble cross referencing parts. It's not hard at all. Sometimes it does take knowledge of the parts world to just "know" that one part is similar enough to another for it to work, but most of the time it really is as simple as picking up a book, or making a phone call. It would take hours to put together a "cross reference" and also silly, as for the most part the part manufacturers have already done that. You can go to your local parts store and have them get you a Prime Line, or Stens book. It won't have prices, but it will let you find the part you need. Sometimes you can just visit, NAPA, or O'Reilly's web page, type in a part number and it will cross it and give you the matched part right away. At least for simple things such as solenoids, ign switches, relays, headlights, v-regs and the like. Some things, are only available OEM.
Tags
782
