Old 10-15-2014, 06:58 PM
chucky79 chucky79 is offline
Ok so I'm at a loss..... How in the world am I supposed to get a wrench on the top and the bottom to secure this silly engine. There is NO room no matter how I try. Even if I lift the motor to drop new bolts in how in the heck do I get a ratchet in there after the fact in order to tighten it all up? Any help fellers?
Old 10-15-2014, 07:02 PM
And I think the bolts have to come from bottom and the nut goes on top because there is no clearance underneith to have the bolt protruding past the nut.
Old 10-15-2014, 07:43 PM
Darrell Darrell is offline
The only way i know to get the bolts/nuts/spacers back in is to pull the engine and adaptor plate.
It is no big deal to do that. I pull the fuel tank and stand , hood and grill , unhook your wires , cables , driveshaft , etc .. and six bolts that hold the adaptor plate.
It sounds worse than what it really is.
Old 10-15-2014, 07:47 PM
So the process is to mount the engine to the plate first then set the whole unit back in and mount the plate to the frame?
Old 10-15-2014, 07:49 PM
Thats it !!
Old 10-15-2014, 07:54 PM
I am pretty sure there is service manual in the Tech library for tractors on how to do it. You probably might want to look thru it , it would probably help.
Old 10-15-2014, 10:12 PM
Thanks. I'll look there too!
