Old 11-04-2014, 08:43 AM
GTKid GTKid is offline
Default 1282 hydro wear items
My 1282 has a lil bit of speed up in the hydro linkage, if you move the hydro handle, it will take another half second to get to that speed. What are the first things that wear on the hydro that would affect it? Thx in advance
Only a 1282 with ~700 hrs(serial 729357)...
Just red and black and ain't goin back!
Old 11-04-2014, 09:02 AM
I'd take a look at the springs in the trunnion along with play in the linkage. I'd also do a fluid and filter change if you haven't done it recently.
Old 11-04-2014, 09:36 AM
jimbob200521's Avatar
What this guy said ^^
Here's a link that may help you out
http://www.onlycubcadets.net/forum/s...ead.php?t=4635
-Ryan
Old 11-04-2014, 09:52 AM
This thing sat outside for a lil while so I'll do a fluid change and get the springs too. Would 700 hours wear it out that much?
Old 11-04-2014, 10:32 AM
Berwil's Avatar
Berwil Berwil is offline
I have a 1/2 acre, lots of turning around, forward to reverse, start and stops. If you change direction 100 times an hr (once change every 36 seconds), that's 70,000 direction changes on your machine! It may need a slight adjustment.
Bill
Old 11-04-2014, 10:34 AM
I would say it depends largely on use rather the just plain hours. You could have a tractor with 700 hours but it was constant stop, go, uphill, downhill, forward, reverse, etc and it could have worn notches. Then take a machine that has 1600 hours but it was used to mow a large area at a constant speed and it will hardly be worn.
Take note, though; this is just my personal opinion. I've had numerous machines ranging from a 127 to a 2284. A recent 129 I had had a trunnion in great shape, drove great, no creep, held speed good on hills, etc. However, on the other hand, the 2284 I have now had a pretty worn and beat up swash plate and when I got it, it was literally barely drivable (just enough to get it into the garage, as a matter of fact). So that right there just goes to show you how you use and maintain a machine matters more than just how old it is.
All that being said, I wouldn't think a 700 hour machine would be too bad, but who knows. Remove the fenders and take a look!
-Ryan
Old 11-04-2014, 12:39 PM
Got new rag joints for the drive shaft and brake return spring but forgot the trunion springs and hydro fluid I'll pull the fenders and take a look at the linkage
