Old 11-04-2014, 11:31 AM
rwairforce rwairforce is offline
Default 1864 hydro fluid change. NOT???
I just read in the manual where it instructs to remove the drain plug and drain and replace the trans oil only on the 1863.
It doesn't mention doing this for the 1864. I find that surprising. This was pointed out to me by a seller of an 1864 that I inquired about.
I awaiteth the light to be shineth upon me.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 11-04-2014, 11:32 AM
jimbob200521's Avatar
Hmm...I've got an actual 1863/1864 manual at home so I'll have to check this out
-Ryan
Old 11-04-2014, 08:11 PM
hogfly hogfly is offline
Default fluid change
the only difference in 1863 and 64 is power steering i have same ? do you really need to change hydro fluid and filter i do hvac service you would not belive the people that thinks freon needs changed or added its in there for life if you you need gas ITS LEAKING what about hydro fluid
Old 11-04-2014, 08:26 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
1864 also has a Sundstrand transmission. 1863 has a Hydrogear.
Not sure of the comparison to refrigerant. ALL oils need to be serviced periodically for optimum life as they are vented to the atmosphere.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-04-2014, 08:42 PM
I don't care what a book says.... It's oil, it has a filter, it gets changed. If the book doesn't say to do it, it was more than likely a misprint.
Old 11-04-2014, 08:43 PM
bocephus1991's Avatar
All lubricants break down over time. Like Travis said they need to be changed.
Brian
Old 11-04-2014, 09:16 PM
I totally agree.
I thought it was strange myself but I check the manual and it specifically indicates that the draining relates to the 1863..
Page 24 of the manual. It sure doesn't make sense other than being a mistake.
I'll change mine. Don't you love having a choice.
Randy
John Deere 140 H3
Sears: GTV16
Old 11-07-2014, 07:47 PM
yea never gave that a thought we pull vacums no atmosphere we pull below 500 microns like jmech said if it has a filter change it how often not sure
