Old 12-17-2014, 03:57 AM
gstommes gstommes is offline
Default 364 snowblower on a 1650
Has anyone put a 364 blower on a quiet line? I am attempting to put it on my 1650 but I am missing some parts to mounting brackets for the rear and have the wrong pulley. If anyone would have pictures that would help me a lot. Thank you.
Old 12-17-2014, 06:20 AM
IIRC, the 190-364 Snow Blower was originally designed for the Cub cadet 82 Series tractors.
It should mount up but the drive pulley and belt would have to match the PTO size on the Q/L tractors.
Old 12-17-2014, 08:25 AM
jimbob200521's Avatar
Is that...ducting I see going from the front into the cab for heat?
-Ryan
Old 12-17-2014, 06:14 PM
Yes it is duct work, like an old manifold heater. That cab is homemade. The guy I bought it from said he copied his brothers cozy cab but added that. It stays nice and warm in there and makes moving snow fun.
I have a pulley that must of came off of an 82 series tractor. It has a 5/8 belt and it has a offset in it. It will not work on my tractor. I would like to find the right pulley, otherwise I will have to resort to making something else work. If I at least had some pictures would help me a lot.
Old 12-17-2014, 07:59 PM
I don't mean to derail the thread, but I would really like to see more pics of the ductwork for the heating. Is there a fan in the cab that pulls the heat to it?
-Ryan
Old 12-17-2014, 11:57 PM
I hope this helps you. I can take more.
Old 12-18-2014, 12:08 AM
Oh yeah no fan enough heat gradually makes it in there. I extended the exhaust through a hole with leather around it with a price of conduit. When it is below zero I stay comfortable with a sweatshirt. I think the cab will very nice with the snowblower too.
Old 12-18-2014, 12:47 AM
Berwil's Avatar
Berwil Berwil is offline
That heater setup is pretty cool.
What do you mean there is an offset? The input shaft is not long enough to line the pulley up with the tractor pto? Some pics would be helpful. Like Roland said, it was made for an '82 series, there is no "right" pulley for your tractor. Not saying it can't work, just may have to think outside the box. Maybe get a new pulley for a 1/2" belt? I have a 1450, and I use 1/2" belts to run my mower deck and thrower.
Bill
Old 12-18-2014, 11:51 AM
In the manual they make them to fit on quiet line tractors from the factory. The pulley I have is offset, like a car rim. Because of that when I put it on my tractor the pulleys don't line up. I would imagine the tractor that this pulley is for, the engine sat more forward. I will order a pulley and machine it to work but it would be nice to see what was correct and have an exact diameter measurement. And set how they mounted the long tubes that go under the tractor.
