Old 12-18-2014, 08:17 PM
Sounds sort of like a top fueler or a funny car, it's all in the clutch to get it hooked up and down the track.
Don my wife looked at the vid and said she thinks your hot.
Old 12-18-2014, 08:57 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
She was probably taking about the background flames
Old 12-18-2014, 09:15 PM
Maybe I'm lucky your not in VA
Old 12-18-2014, 09:48 PM
dvogtvpe's Avatar
the one thing you don't realize watching the vid is there were 30 tractors in the finals that day. they just used the top 7 since that made up a 1/2 hour TV slot. before the finals ran there were 5 heats that totaled over 80 tractors. they took the top 6 from each heat to the finals.so there was a little competition to get there
Old 12-18-2014, 09:50 PM
Well you made the final cut so "You Da Man"
Old 12-18-2014, 10:24 PM
austin8214's Avatar
80 tractors in a class would be awesome.
Old 12-19-2014, 11:38 AM
bschmittling bschmittling is offline
you will find on an open RPM engine you almost use the gear as a governor to help control where the engine will run in the RPM band.
Austin is right on the money. WOT and easy on the clutch. in the NQS vid that I posted its not uncommon to ride the clutch 20 to 30 feet t keep the revs up . you should see some of the clutch's we take out that are all burnt blue,.
Thanks for sharing guys. I'll give that a try next year. Don, you da man
Old 01-22-2015, 05:16 PM
Would a 20% under drive drop the stock 19 tooth second gear to a 16 tooth equivalent? Also, would a 16 tooth second gear be a good choice if you were only using one pulling gear? The engine is only 12 hp now but I plan to try and get 16 hp or so out of it.
Old 01-22-2015, 06:55 PM
dvogtvpe's Avatar
20 % is pretty close, what size tires are you planning on running?
Old 01-23-2015, 10:35 AM
I have 23s and 26s so I can run different classes.
