#31
I have not gotten any firm commitments so I have not done any more on this. I'll need to order at least 6 so if I get commitments for the 6 I'll proceed. Only thing I did was to decide that if I make them I'm going to use a 6203 bearing because you can pick them up at TSC along with the 5/8" X 3/8" shoulder bushings.
#32
I will see what I can do. I may end up purchasing more pulleys than I first wanted to buy. I certainly want two. I'm not sure about the other four. I will have to get back with you. BTW, the 6203 bearing is metric and the ID of the bearing or the OD of the bushing is 17 mm, not 5/8. 5/8 is just slightly smaller than 17 mm, so a 5/8 bolt will easily go through a 6203 bearing.
Matthew B ![]() 1972 129 w/hydraulic lift and head light option soon to be repainted |
#33
Did anything happen with this? Put me down for (2) pulleys if you are planning on making any.
#34
Just found this discussion. Put me down for a pair of pulleys.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
#35
#36
I thought the OP was going to have sets machined that take the replaceable bearing? That's what I would like to get.
#37
I was looking for the replaceable bearing style too.
| Tags |
| mule drive, pulley, tiller |
| Thread Tools | |
| Display Modes | |
