#21
garbage can,...
multiple dollar store jugs of the "works" toilet bowl cleaner... drop in... pull out in a day or so.. hose off... prime... done |
#22
The shop pic was my garage before I got the shop finished. This is Cub Ville.
#23
Love to see some pics. My problem is most of the stuff I'm working on won't fit in a garbage can, more like a small pool.
#24
that would get expensive to fill...i just cleaned some parts yesterday..i'll find something rusy and show ya..works geat for a plastic contaier full of nuts and bolts too
#26
I've got an old 100lb pot blaster and a 351 Windsor powered air compressor.
I have to stand 10 feet away to do sheet metal
----------------------------------- 106 Needs a clutch-------107 (Lent to my brother) 123 w/hydro lift & qa36--126 w/creeper and lift 127 restored--------------129 50" mowin machine 129 w/hydro lift-----------147 plow horse w/tiller 149 auction score---------782 KT17SII |
#27
Mine is a 55 gallon poly drum on a stand. There is a 14 inch square opening for glass and arm holes. A shop vac clears the dust. The last time I was at tractor supply I loaded up on media but so fzr havr only used sand. Whimpy compressor but ebough for the HF blasting gun.
Sometime i plan to try a DIY rig for soda blasting carbs, I have been playing with electrolysis with washing soda on a small scale. It is now my favotite way to remove rust. It takes a lot longer but is very little work. Then there is this setup, a lot of work to get from here from there.
| Thread Tools | |
| Display Modes | |
